New car faults
Hello all. I've recently purchased a mk2 vrs (petrol) after my mk1 was written off. But with most cars there's some little faults with it so I need your help. The car runs fine but it's lumpy on idle. There's no faults on a code reader. I've had a look on other forums and it points to it being the pcv,but wouldn't this throw up a code? I've also tried to have a look but I can't get the plastic cover off is there a nack to this? Lastly I went to get the aircon recharged but was told there's a leak around the compressor. Would I need to get this serviced to check for cracked seals. If anyone knows where I can get this done around the portsmouth area. Thanks for reading and any help will be appreciated.
Does the engine cover look like this?
Thanks silver, yep thats the same engine cover but mines not as clean. I'm using a Autel reader which was fine on my mk1. But theres no codes listed on the ecu so it may not be the pcv?
I had same issue. No codes. Was the PCV. Does yours self rev when stationary?
Sent from my Galaxy S5
no it's just lumpy when i'm stationary.
