Airbag Fault
Hi all,
I swapped out the steering angle sensor module as previous one was acting up got a salvaged part which was 100% (matching part number) so all went well until I start up and now I've an airbag fault! I know the airbag is ok as it didn't show a fault previously, so how do I rectify this? Can I disconnect the battery to clear to car's memory or is it a plug in job?
Sent from my C6603 using Tapatalk
Edited by KeithbagVRS
Did you turn the ignition on with the airbag disconnected?
If so you'll have to clear the fault with vcds.
Ah right cool, think I did by accident, I'll get it plugged in thanks
