Custom LED cornering lights and rear reflector Mod
After the Mercedes LED DRLs into the foglight housings I decided to fit some custom LED cornering fogs.
They have been fitted into the grilles which is excellent as they do sit at around a 30 deg angle sidewards.
I have used some 12w COB chips with the following specs:
Vf = 18-24v Af = 500ma = 12w output power.  As they have a forward voltage of 24v I have some 12-24v convertors between the harness and the COB chips.
These are plug and play onto the cars Fog light harness which means they can be removed in seconds.
They are currently programmed as cornering lights and coming home / leaving home lights.
Ignore the brightness as pictured from the front as you can never get brightness appreciation through a phone camera, the light to the side of the car is all from these chips, the Mercedes DRL's only shine light directly forward. The headlights are off in all pictures.
56059B74-24DE-475A-B787-4A57E9E37EA0_zps
EB317775-A452-44E3-8D54-8B8AE9FEF994_zps
A63E7347-92A1-46D9-9303-B2644C6C055D_zps
841EBEC2-CABE-4669-8C56-914B2E5CFBCD_zps
777100F1-8633-4724-9C10-3DC5806211F9_zps
I have also hate the rear reflector on the vRS (especially at night) going all the way across the rear of the bumper.  I have tried to black it out as a trial leaving 2 parts each side.
9C4FC230-BCF4-409C-A29F-C8D338BA7356_zps
