The last straw?
Well after spending a good amount of money on tyres, servicing and brakes
This happens...
Switching from main to dipped headlights.... No dipped only side...
anything from 20 - 1 min later dips come on...
This on the back of a weekend where i've done all discs and pads....
No probem if i can get the wheels off.!!!
all four wheels needed a breaker bar plus a peice of tubing to shift the wheel bolts..
The care taken when servicing your car!!!!!
cheesed off to be polite!!!!!!
Dazz :mad:
Eek.
Hopefully someone will have an idea for your lighting issue (staying well clear of any puns :D)
Wheel "bonding" problem is a PITA and fairly common....if you have space a good kick apparently can do the job...I used a crow bar wrapped in a towel.
Not heard of the light problem before though.
Copper grease on the rear hub face as this is where it binds.. Makes removal
easier...
No this was not the issue.. The issue was wheel bolts tightened way to tight
requiring breaker + extension tubing to undo, including locking wheel bolts
I thought dealer should have torqued to Skoda spec?
cheers
Dazz
