19" Alloy specs?
Does anyone know what the specs are for the factory 18 & 19" alloys?  Ideally want to get some 19" aftermarket alloys for my estate when it arrives but not sure what offset and diameter to get.  I assume the PCD is 5x112.  Also re the front and rear the same?
Edited by hardyp
Page 262
235/45/18” 94W
8J x 18”
ET44
5x112
235/40/19” 96W
8J x 19”
ET44
5x112
Page 262
235/45/18” 94W
8J x 18”
ET44
5x112
235/40/19” 96W
8J x 19”
ET44
5x112
Thanks for that, would ET45 be okay as that's what most aftermarket ones seem to be.  Are there any other important measurements I need to take into account that I've not listed?
Yes 1mm isn’t going to make any difference at all.
You will probably be fine anywhere between ET40 - ET50
The only other bit you need is the centre bore, Škoda use 57.1mm, so some wheels may require a spigot ring to reduce the centre of the wheel down to 57.1mm.
Shame I have 235/35 19" for the mk II  and the mk III Superb is 235/40 19"
