Indicator bulbs
Are the front & rear indicator bulbs for the fabia an OFFSET pin type ? :confused:
Are the front & rear indicator bulbs for the fabia an OFFSET pin type ? :confused: [/font']
yep, if you look at the base of the bulb the pins are offset, I think they are type 581's but not sure on that. someone more knowledgable will be along in a minute.
I swapped mine out for silver ones to de-tango it a bit.
Go to powerbulbs.co.uk - drop in the model of the car and it will tell you the exact type of bulb to use :)
Cool !! :thumbup:
No problem :)
The indicator bulbs are actually not that hard to change, especially when you compare it to changing sidelights/main beam on the Furby (noticing you've got Xenons as well ;))
There are several people here who have changed those bulbs too, but I paid my dealer a little as it is a pain to change IMHO.
Thanks. :thumbup:
