ECU update for better DPF operation PD engines ANYONE KNOW ABOUT THESE ?
Hi all, I've recently read somewhere about a ecu update skoda came up with for better DPF operation on the PD engined vehicles, does anyone know about this update or what its technical name is ?? Please any help with this information would be gratefully received.
There might be a newer software for the ECU but there isn't normally a change log saying what's changed.
If you have a VCDS autoscan I can take a look at the flash files I have and see if there is anything obvious for your car.
Don't know if this is what you require, its an oldish scan, if its not what you require let me know how to scan the info you do want and I'll get it for you. Its an 1Z5 chassis despite saying 1U for some reason ?
Thanks in advance Andy
Saturday,21,February,2015,19:44:33:55062
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBKE21Z98223****   Mileage: 204290km/126939miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 TF    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  2050
   Revision: --H08---    Serial number: SKX7Z0H832M0CA
   Coding: 0000172
   Shop #: WSC 73430 000 00000
   VCID: 76E851B201102BAEA59
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 H    HW: 1Z0 920 912 H
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: SKX7Z0H832M0CA
   Coding: 0007401
   Shop #: WSC 23017 576 01112
   VCID: 3A70858275888FCE811
1 Fault Found
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 228
                    Mileage: 204289 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:20:04
End   ---------------------------------------------------------------------
There are the files that are closest to that part number:
03G906021JC_2118.sgo
03G906021LB_9251.sgo
03G906021LD_9902.sgo
03G906021LE_9903.sgo
03G906021MC_9948.sgo
None of them match the exact part number and only the first looks remotely sensible in terms of SW version.
I don't think I'd want to risk an ECU over it...
Ok, thanks for the info, I'll make some more enquires before I do anything anyway... Thanks for the post tho
