Cheap Maxidot Cluster
Very cheap and make an offer
The front fascia can be swopped with your original one
Why do cheap petrol VRS ones never come up :(
So £20 posted for this is a good price then? :D
It's hopefully on its way to me now.
Eddie - I guess I need to speak to you about getting this fitted in my pre-FL VRS 2008....?
Bargain...
That is a bargain. I though I did well at £50 for mine!
Is your VRS a PD170?
Yes PD170.
Who coded yours? And did you have to swap the fronts over?
Cool. Just checking as PD and CR aren't interchangeable I don't think.
Eddie-NL did it for me.
I swapped the front Perspex cover over as the one I got was broken. It just unscrews then unclips.
Phil
Cheers. I'll wait for it to turn up and then get Eddie on the case.
You can apparently use a CR cluster on a PD car no problem.
The facelift clusters can even be used in a pre-facelift car with a bit of fettling.
Edited by softscoop
Mine's still sitting in the box it arrived in :(
Too busy at the moment to get sorted.
Mine sat for weeks before I managed to get Eddie to fit it... the suspense was unbearable seeing it sat there and not able to fit it! lol
hmm, if only i knew how much it would cost to fit I might place a cheeky bid. Does Eddie charge a set amount for fitting these please Phil?
My local VAG independent garage quoted £40 to swap and code a used cluster.
Don't quote me on this as I can't remember exactly and he may charge more/less (guess that's up to him).
He came to me (he was going somewhere in the North and detoured via York) and charged me £60 I think.
£40 is a good price. But knowing how many Eddie has done etc I would sooner pay the £60.
He is in Great Yarmouth.
Phil
He is a 4 hour drive from mine, not far from my uncle but I fear my wife may kill me. On top of that I keep looking at superbs although a cluster change would be cheaper  :D
Think Eddie said about £40.
He's about 6 hours away but I usually travel down to Kent reasonably regularly do would drop in on the way down. Just not had a chance yet.
