New key.
Hi guys
Just had a new key cut for my fabia, I put it in the ignition turnt the key and it hesitated to start and then fired up but I had a coil light come on then a car light with a flashing key symbol.
I took key out inserted the old one car started no problem and no warning lights.
Any ideas?
Sent from my SM-N910F using Tapatalk
did you get the immo chip coded to the car?
No I haven't I just took the internals from old key put them into new fob and got the key cut
Well if the old key still works you haven't swapped everything.
There is a small glass chip inside the key, if they breaks your knackered.
Ah ok I'll have a look.
