Towbar electrics caravan fridge side
My octavia was fitted with a towbar twin electrics had a permanent live feed to boot for the fridge and other stuff. Where is this live feed picked up from as was using live feed to power a 12v plug but has stopped working fuse is ok boot end but not sure where at the front end feed is took from or if it has another fuse
Sent from my SM-G900F using Tapatalk
It all depends who fitted the towbar in first place,
When i wired my bypass relay unit in i took power from fusebox under dash behind headlight switch,
I fused it in fuebox and then ran it to back of car to bypass relay, i would start there
I will have a look there I kno it's Def not fed direct from the battery and I kno some cars have a wire that you connect to that's been solely fitted for the feed
