Sound system upgrade help?
Right, got plans for a decent sound system in the motor,
Running Vibe Slick 6 in the front doors and some old Pioneer TS speakers in the back, original Renault tweeters,
I plan to strip the whole car down to a bare shell and sound deaden it, got a JVC Bluetooth stereo at current which is good with these speakers. I'd like to do a decent and discrete install, can anyone recommend products etc
Depends on what you are after Jack. Do you want thumping bass or to hear all the highs and lows?
If it's the latter. Plenty of sound deadening and use wooden baffles between door and speaker. Also a amp with a good gauge wire and earth will help.
Sent from my Galaxy S5
Shh, that doesn't interest me as the door cards would rattle apart ;)
Nope I'm just after some decent sound, stereo settings are all to buttery too
The Vibe speakers need to be solid and not able to vibrate / rattle.
Personally I'd install an amp and connect the speakers upto that.
They're not coming out of that door card anytime soon, wood screws FTW
Just get an amp. Have the speakers wired up to that. Maybe a sub if wanted
Cheers, will do when I get replacement wiring done and sound deaden it all.
If you need a hand give me a shout done a couple before. Might be easier to do it all in one go. I.E wires then sound deadening
Legend will do, still waiting to see what car to do it on
How much is the sound deadening? I've thought of doing that myself
Local ICE shop said a pack of Dynamat for £150 is usually enough to do the car, but it depends how far you plan on going with it.
Edited by fabiamk2SE
