Need help with my VCDS results.
Hi,
I've got an intermittent EML on, a passenger rear brake light not working and intermittent problems with the passenger front window not always rising on first clicked.
I presume I need to replace the G294 sensor. Is this right?
Where do I start with the wiring fault? I did have my passenger window regulator replaced a year ago if this helps.
Here are my results. Any help is appricated!
Saturday,19,September,2015,16:19:26:53046
Mileage: 130750km-81244mi   Repair Order: 3
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: *REMOVED* Mileage: 130750km-81244miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 CM    HW: Hardware No
   Component: MED9.5.10        00 7001
   Revision: --H01---    Serial number: SKZ7Z0E3045355
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 70E9A607636C25A19EF-8025
1 Fault Found
006418 - Pressure Sensor for Brake Boost (G294)
               P1912 - 001 - Short to Plus
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130758 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:15:24
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 36.0°C
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8B353B6EB28AD9575-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047
   Component: Climatic PQ35   004 0201
   Shop #: WSC 00000 000 00000
1 Fault Found
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003347352
   Coding: 008C0F030004140000110D000000000000087B075C
   Shop #: WSC 25043 576 17493
   VCID: 397F5B237096A4E9691-806C
   Subsystem 1 - Part No: 1Z2 955 119 A
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 25043
1 Fault Found
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: Q4 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0ELF24
   Coding: 0020788
   VCID: 377B5D1B4682B2999F5-8062
   Subsystem 1 - Serial number: 6332MSME0A1D1E67N
   Subsystem 2 - Serial number: 6342MSME0A1D6870H
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000012
   VCID: 76E5901F01080B91443-8023
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 B
   Component: KOMBIINSTRUMENT VD1 3562
   Coding: 0003401
   Shop #: WSC 25043 067 57207
   VCID: 326D6C0FADE057B1A8B-8067
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105525860F
   Coding: 3D3F0340071303
   VCID: 2A5D746F85301F7110B-807F
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3562
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000756
   VCID: 3665501F41884B91843-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 316F6303A8E66CA9D11-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8505485F861004CC
   VCID: 79FF9B23301664E9291-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000756
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       012 0026
   Revision: 00012000    Serial number: SKZ7Z3E0009521
   Coding: 0000402
   VCID: 2D577F73B4DE0849F59-8078
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2405
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 3363690B52FA5EB9A3D-8066
End-------------------------(Elapsed Time: 01:57)--------------------------
Bump,
I've removed the VIN from the report.  You can never be sure who might use that for the wrong reasons, although its easy enough to trawl a scrapyard for them.
