oil pressure sensor
hi I have a mk1 skoda fabia which has the oil light flashing and beeping iv checked the oil and it was a little low so topped up but oil light is still flashing and beeping iv read on here that it could be the oil pressure sensor
would I be right in thinking that the oil pressure sensor is to the right of the oil filter or could some tell me where its located please with an image if possible
many thanks
Your car is the 1.4 MPI, right?
The oil pressure sender is part number 047919081B
In my case, when it started flashing and beeping it was caused by a faulty wire. The sensor went faulty when it started to leak badly about 7 months later (and about 3700miles). In that trip (when it started to leak) I kind of pushed it, not that hard, but I've changed gears over 3500rpm. I've lost over 1litre of oil through that switch before I've got home, so the things were pretty ugly.
Edited by Alexandru
