4x ContiWinterContact TS830 on OEM winter wheels for MK2 Octavia and others.
I have a set of four 205/55 R16 91H Continental ContiWinterContact TS830 each with 5-6mm across the full tread.
They are currently fitted on genuine winter steels for a FL MK2 Octavia, they are 6JX16 H2 ET50 5x112 (8P0 601 027) which is the listed size in the owners manual for winter use and are perfect for chains. Not that I'd expect you would need them!
Also included are:
- four genuine Skoda Superb wheel trims - 3U0 601 147 A
- four genuine VW Caddy/Golf hubcaps - 2K0 601 149 C (apologies, I haven't got photos so used stock images for these hubcaps)
Personally, I preferred the all black look of the VW hubcaps but as both are included the choice is yours. All items are used so have the odd scuff and scrape but are in good serviceable condition and will easily see you through these cold winter months.
From what I understand these are standard fitment for the following vehicles but I would expect they are OK on most 5x112 VAG vehicles, I'd advise you check before buying.
- Audi A3/S3 2004-2013
- Skoda Octavia 2004-2013
- Skoda Yeti 2010-2013
- VW Golf 2004-2013
- VW Jetta 2006-2013
- VW Touran 2006-2013
Ideally you'd collect but I'm sure arrangements can be made to post if necessary.
I'm looking for £200 for the lot and they can be collected from either Cambridge, Dereham  or near Ely.
Provisionally sold, thanks!
Now collected.
Guest
