Remove armrest lid from jumbo box
Hello! :)
Im wondering if anyone knows how to remove the lid of the jumbo box ? :)
Bought myself a new leather cover for the armrest :) ( not the kind you can put over the old one )
Cant see any screws.. :S
If its possible to slide it out or something.. :S
Thanks for all the help :)
Solved!
Took some time to look at the lid, and found out how to take it off :)
5min job :)
Please could you advise what you did? I'd been looking at replacing mine but couldn't figure out how to get the old one off. Does it involve removing the rear air vents?
Thanks.
Dont need to remove anything else, you see under the lid, theres is a plastic cover.
Then you take a flat screwdriver in each corner, and separate the plastic cover from the actual lid. Theres is 4 clips in total.
When this is done you push the lid towards the gear knob, and you see that the lid stops against 2 bent metal clips ( i dont know the word, im from norway :P )
Just bend the 2 metal clips, then you slide the lid of the box, then you push the 2 metal clips back in place for when you are going to assemble it :)
Then you put you new leather over the old one, pop back the plastic cover before you slide it back in place :)
Took about 15min :)
Hope this helps ;)
Great. Thank you.
