Alternative DRL's?
I'm not a big fan of aftermarket LED DRL's, they always look a bit Halfords.
The DRL's on your Superb are already pretty good, being housed inside the main headlight.
It has to be said though if buying a new Superb I'd always pay more for the bi-xenon headlights, if not for the integrated LED DRL's and indicators alone!
+1 on both of these
mine are in the foglamps i think?
look a bit dowdy
I thought all the FL cars had them in the headlights now?
If they are in the foglights then a pair of CREE LED’s will make a huge improvement.
LED v STD filament bulb
Then when the LED’s started to fail:
LED v’s CREE LED (right)
They are in the headlight, I took this picture from an earlier thread (sorry if it brings back bad memories!).
The DRL's utilise the main beam bulb, inboard of the dipped headlight projectors.
The bulb performs three roles...
Dim = side lights (clarification required here, there might be a W5W bulb hidden in there somewhere)
Bright = DRL's
Brightest = Main beam
11807602_1023148914364689_60057871578457
Can't see any W5W bulb in there, the manual is as clear as mud too...
01_Bi-xenon-headlights-with-dynamic-angl
ill give it a bash.....not expensive anyway
