Illuminated speedo needles Octavia Mk1
Is it possible to illuminate the needles on the clocks of a Mk1 Octavia? I've had the standard clocks upgraded to L&K clocks, are all coded in but the person doing it new how to on Golf Mk4 but not Octavia Mk1. I'm hoping it can as it would finish off the install. Any help would be really appreciated. 73e53284d98f613129cc034243d98d32.jpg
You need to edit the hexadecimal coding of the clocks eeprom using the likes of vag tacho to extract the coding then a hex editor to change the values.
Unless someone knows the correct values to change and what to change them to I'm afraid you're not going to have much luck.
