Moaning Noise from the rear (!)
Upon reversing in the vRS, ive started to notice a moaning sort of noise coming from the back end somewhere. :confused:
Its almost as if the handbrake's been left on slightly, or something like that.
Anyone encountered a similar problem?
Cheers,
Geese
So many replies but not all would help.
Yep it's a common one, most do it at sometime. Do a search and up something will pop (up) that may help with the moaning from your rear
This has been covered loads of times, use our wonderfull search function.
Cheers for that, Lummox.:thumbup:
Did as you said and it looks like i've found the cure.
Geese
Mine does it ( Octy ) when I touch the brakes whilst reversing .. its the pads just rubbing on the discs moving slightly in the caliper .. mebbe your pads are just contacting the discs slightly ?
or - as you have disposed of next doors dog / cat / child , mebbe its the wife in throws of passion ?! :))
If you getting the usual moaning noise its nothing to do with brake pads.
Oh ...
a sort of a deep note vibration type noise as I touch the brakes ? Doesnt do it whilst reversing and not touching brakes ,, and doesnt do it with firm brake pressure .. only light pressure
is thatthe usual one ??
Yep
