Battery Replacement in Fabia 1.4 MPI
:confused: Help Anybody
How do I get the Battery out of the holder. Successfully opened battery box and released terminals, but cannot shift the battery. Don't see any obvious securing brackets but it is rock solid so must be bolted somewhere.
Mick
If it's anything like the TDI, it's held on with a small metal plate which sits over the front bottom lip (can I say front bottom on here? :rofl: ) of the battery and bolted in place. I forget what size socket I used on it, but I remember it being quite a fiddly operation. Obviously with the 1.4, you might have a bit more room under the bonnet to work :D
Chris
13mm bolt down the front behind the headlamp as you look down at it.
