PD100 clutch upgrade - G60?
On the look for a turbo for my PD100 possibly a pd150 or hybrid etc so I'm also going to uprate my clutch
Car already has a single mass from factory
Will G60 clutch fit my car ?
Yes, I believe so :)
one of the bonus points on the PD100 over the PD130 etc... No 6 speed box means you can play with whatever clutch and flywheel setup you like really.
Any recommendations ?
Also will I have to change my flywheel I've checked the sizes and g60/vr6 and mine clutch are all 228/230mm, so going on that all I should need is pressure plate and friction and new bearing?
Edited by furbyPD100
even though its a solid flywheel and dont "really wear at all" i would still change it for the one suited to the clutch, being a solid flywheel they can be picked up nice and cheap anyway so for piece of mind youve changed the clutch, flywheel and release bearing.
If you are looking for a turbo and upgrading the clutch it sounds as if you are going for a bit more oomph. Interested to hear what turbo you are going to use.
I have been thinking about an upgraded pd100 Fabia but my main interest is low-down torque, don't want to sacrifice flexibility for bhp above 2500 as I do most of my driving between 1200 and 2500.
Have you had your car remapped?
Some of the standard upgrades on a PD100 are PD130 turbo and injectors, I believe, as they're readily available and cheap. With a remap I think you are looking at around the 170 mark and you can get a custom map so that the power band is lower.
So going on that the part number for my flywheel is 037105273c which also comes back as a G60 flywheel, I should be good to go with a vr6 clutch
just a heads up, you wont need to change the injectors on the pd100 fabia to 130 injectors if youre just going to go for a pd130 turbo.
the 100 injectors will make 170 quite easily.
Also, here is a link to the clutch that you should get. its genuine SACHS and massively reduced. you can also use the code extra10 or even mot10 for an extra 10% off too making it under £100 for a new clutch :)
http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1996/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?641440660&1&4003e5bd875dcca7496ab2e8bc3dab4356496e2c&000069
