help with window regulator
i brought a fabia the passenger window cables where broken so i brought new window door panel and fitted but the regulator motor was in the boot now i have gone to refit the motor and the little white nylon gear bush part that that joins the two together through the door is missing, does any body have any idea what this part is called and a part number to order in, as im struggling to find one in uk, here is a ebay link to a german shop selling them http://www.ebay.co.uk/itm/1x-CLIPS-FENSTERHEBER-REPARATURSATZ-ROLLE-GEAR-VW-SEAT-SKODA-LINKS-ODER-RECHTS-/171849142151?hash=item280301cf87:g:1-sAAOSwMmBVmkkk
What area are you?
I am sure someone locally to you may have an old window carrier with one still attached.
DB.
