Cupra R Brembos
Just won some k1 brembos on ebay, but starting to wonder if they will fit as they are from a k1 or mk2 se cupra r.
Will they fit fit but need new disks and pads (5x100 disks) or have I dropped a clanger and got the wrong ones
Its more the compatability of the brake carrier I suspect.  If that is compatible in theory would work with right disc size/PCD, and you'll probably be able to use same pads.
I'm sure there was discussion about bolt spacings and carriers... Best holler @ Tech1e.
K1's didn't come with brembo's. Only the Mk1 LCR and the brand new ones have brembo's.
Edited by tommccabevRS
Yep, just found this out guy selling was like "yeah they are the same as the lcr ones just from a mk2 Leon" took pictures and saw straight away they were not 4 pots.
