RS6 alloys with Goodyear gsd3 quote
Hi,
Just got a quote for the above, £800. Which i dont consider bad, as the tyres are £120 each.
The strange thing was they quoted for 4 x 17" rs6 replica alloys fitted with 225/45r17 goodyear GSD3.
The conserning bit 225. Is this likely to be an issue (rubbing etc.) and shouldnt they be 40r17
Thanks in advance.
ItsOnlyMe
For an Octavia, there's little difference between 205/50 R17s and 225/45 R17s - The 225 / 205 bit does not mean one tyre is 20mm wider - Its merely an expression of the sidewall size in % terms.
For a Fabia though 225/45s are a no-no, and 205/40 (or even 215/40) are the best ones to go for. :)
Go for 215/40, i've got 205's and there a little stretched
The 225 / 205 bit does not mean one tyre is 20mm wider - Its merely an expression of the sidewall size in % terms.QUOTE]
I thought it was the opposite - 225 IS the width and then the sidewall is the percentage, ie 225/ 50 = 225mm width 112.5mm sidewall height (50% of 225)
GSD3's can be got MUCH cheaper than
