W5W
Hi guys anyone know how to replace
W5w bulbs
On skoda fabia 2002
1.4 MPI
thanks help
That would be the sidelights I guess...you will need to open the bonnet and take off the headlamp mask in order to replace them.
– Pull out the light bulb and socket on the connector -arrow-.
– After replacing the bulb, press socket and bulb fully into the reflector.
It will be an easy job on the driver side and you'll need tiny hands to do it on the other one.
Edited by Alexandru
On the passenger side there is sometimes a plastic cover on the front of the battery box that slides out by pulling it upwards. Gives enough room to get into the back of the headlight.
+1 to TMB's comment - the Haynes manual says to remove the battery and box to access the light on that side, but if you remove that plastic piece there is enough room so you don't need to. Did this myself recently.
