Rear Passenger side Fog Light?
Hi,
I tried a couple of new double pin bulbs but only 1 filament lights up instead of 2 filaments when I put on the fog light.
Why is that?
The Passenger side rear fog light doesn't work on an Octavia MKII.
I think there's a bulb and it is wired up but it's turned off from the factory.
Ok they should have made it a single pin bulb to avoid the confusion :|
Thanks,
You have to do the coding with VCDS if you want to make both rear fog light work.
Sent from my GT-I9195 using Tapatalk
It gets even more confusing on some models.
My 2008 estate has double filament 21W/5W bulbs (brake/tail & fog/tail) yet my 2007 hatchback had single filament bulbs (the CANBUS altered the brightness for the different functions).
