How do I remove the Radio/Stereo?
This might seem a silly question because there are videos and explanations across the web except, I've looked at them and still can't get the *@£$!&* Bolero radio/stereo out.
I've removed the fascias and I've removed the 4 torx screws at the corners of the radio and it still won't budge. And it's not a case of being tight or a wire caught - it is definitely locked solid, won't move even 1/2 mm. I can't see any other screws - it feels as though there are several more screws still holding it. I've poked down various slots with hacksaw blades in case there's a release latch somewhere but if there is, I can't find it.
There's not a locking bolt hidden away in the glove compartment or engine compartment by any chance? Or underneath and behind the ventilation controls ... ?
It's a 2011 Octavia SE 1.6 TDi
Thanks,
Larry
Recently changed mine and found that it was a bit stiff on the first attempt to move it. A bit of bravery and it started to move. I had to wiggle it side-to-side after about an inch or so as it seemed to jam there but it did eventually come out. Yours should too! :thumbup:
Try removing the top dash storage box above the stereo. Think it just pops out from memory.
Should be able to then push the stereo from behind.
Phil
