Come filter box?
Has anyone made a come filter box?
:D
Ahaha, amazing reply
Hahaha. Any way of changing the title or is it a case of new post?
Edited by MartM
You can edit you thread title and post if you hit the edit button on your post
Edited by stevobeavo
Back on topic I have the jabbasport cone in a box. It uses the standard filter housing so looks standard
^^^ same here jabbasport cone in a box with pd160 intake works a treat will be trying this on a 300bhp+ fabia once built
Sent from my SM-G900F using Tapatalk
Silky has logged this on his 270 bhp setup and said cone filter spools up slightly early nut doesn't filter as well and once on boost no difference in spool or flow.
Will changing filters after been mapped make a difference? Running a 2260 if that makes any difference.
Any difference will be almost undetectable even with a 2260.
