Steering wheel change
The wheel will physically fit,
your old airbag will obviously not though so you will need a new style airbag,
you may also need to change the plug on the airbags... something that is not advised unless you know what you are doing.
Thanks, would any coding be required ? Who would do this type of wiring work, an auto electrician?
No coding as you are not adding any MFSW buttons, not sure if the horn wiring is the same either TBH, I imagine Eddie-NL will be pretty clued up on it though as he does things like this.
The trick with the airbag is knowing which wire goes where and NOT to solder the wires.
