Emission Light On and Fault code pulled.
Hi All - car in question is a 2006 VW POLO 1.2 9n3
Looking to put the wife's polo up for sale but need to get rid of the pesky emission light which has been on for ever.
I recently replaced a gubbed coil pack and reset the fault codes in the hope that this would sort out the problem but it keeps appearing on the dash. I have just lived with the light being on as the car seems to run fine. Have changed pre-cat lambda sensor in the past as was having problems with erratic idling when car was up to temperature (disconnecting the lambda sensor and renewing it sorted it out) but not been having those issues for some time now.
The (generic Torque app) fault codes currently are:
P0342 - Powertrain. Camshaft Position Sensor "A" Circuit Low Input (Bank 1 or single sensor)
P0030 - Powertrain. HO2S Heater Control Circuit (Bank 1 Sensor 1)
The car began refusing to start therefore I was forced into trying to tackle this problem once and for all...
I have since replaced plugs, another one of the coil packs (looked on the way out), cam sensor and pre-cat lambda. Car now starts first time, every time and seems to be running a lot smoother and leaner on the fuel.
I am left with the fault code:
After deleting the fault code the light doesn't come back on again until the car is up to running temp and only when the ignition is switched off then back on again - on comes the emission light...
Anyone have any pointers what to try next (I have been looking through the fuses but they look okay). Don't want to be throwing much more cash at this just to get a damn light to go out.... I'm sceptical at going to a garage with this as no one has been able to get to the bottom of the problem in the past and just seem to want to swap parts out and charge for fault code reading. As mention previously I am looking to sell the car on and obviously need this sorted before attempting to do so. Will mention that the car has just done 70,000 miles.
I have posted on the VW forums but trying my luck over here.
Cheers for any input folks
