Tracing battery drainage II
Simular problem as a neighbour post ;)
I have drainage  like this:
1 A when I connect amp meter and  after 2-5 sec it drops to 0.6 A
Still too much so I have to disconnect battery when leaving car over night   :(
This is with ignition key out
I found the 110 fuse on battery is routing the drainage
Ripped out all fuses  at side of driver seat -    still leaking
Disconnected alternator cables   -  still bad
Disconnected starter motor  -   still bad
What to look for that is not via any of the fuses ?
Where can i find  possible relays to check ?
I have Skoda Octavia Year 2000
Edit:   forgot about fault code ...    I had 029C = Vehicle voltage terminal 30
Hm, terminal 30 what/where is that ?
Have not checked yet if that code will reappear after clearing
BR Bosse
Edited by sidhabo
Resolved:
Turned out it was the boot light ...
Strange since this was the first thing I was checking
Anyway, checking again this was the problem
All good when I disconnected boot light    (Hope it still will be tomorrow morning ;)   )
Edited by sidhabo
Boot light should be controlled through the boot lock, do you have a dodgy earth to the lock?.
