Just did a diagnostic check on a 2003 fabia estate
Hey guys just wondering what your verdict is in this as some of you may be aware a yound women posted up a post about her 1.4 fabia was stuttering but its not doing it all the time well i have just read the fault codes and it came up with manifold absolute pressure fault the eml will be on and if you drive it a while the triangle with the explanation mark and arrow around it will come up and the epc light but ince you turn it off and back on again it the epc light and triangle light will go out but eml will stay on could this mean the map sensor is breaking down and could this cause it to run rough and explain why it sticks of petrol from the back end
Thanks guys
Rob
can you get the readings  both off and running
Nope did yhe normal check of just ignition on and thats the only fault that came up i reset the obd2 and it cleared the lights but will no doubt come back up when she drives it again
It's always had a whiff of petrol from the filler cap area. Asked the garage and was told it was nothing to worry about.
Did a longish trip in it yesterday and it was absolutely fine there and back. The lights didn't come on until I did a trip across town a couple of hours later. It's also much worse when it's full.
