Quick clutch question
Hi folks, does anyone have a ballpark price for a clutch and DMF replacement at an indy please?
Noticed yesterday that I'm starting to get a bit of tightness in the gear change between 1-2,2-3, and a quick look online suggests it may be the clutch on its way out.
This couldn't happen at a worse time. My car is a taxi and Christmas is the busiest time of the year. I really don't think I will be able to get it into a main dealer before the new year, and can't afford to be off over Christmas so I think I will just have to take a chance that it is the clutch and get it done at an indy.
Cheers.
Ivor.
Thank you for that. Never expected the parts to cost that much [emoji15][emoji15]
Cheers.
Ivor.
Change the concentric slave cylinder (fitted to manual 6 speed 2.0 diesel) whilst the gearbox is off. It is known to fail and is another gearbox off job and it also usually covers the clutch with brake fluid when it fails.
Edited by bigjohn
Change the concentric slave cylinder (fitted to manual 6 speed 2.0 diesel)whilst the gearbox is off. It is known to fail and is another gearbox off job
What are the symptoms of that failing please?
Actually thinking about it - the symptoms you describe - how is reverse?
You get air in the system and eventually can loose brake/clutch fluid which means the clutch not fully released when you put the pedal to the floor (tight gear changes) . Eventually foot to the floor does nothing and you find a pool of brake/clutch fluid under the bell-housing
Make sure the replacement clutch isn't a Sachs one:-
http://www.briskoda.net/forums/topic/363426-clutch-eats-gearbox-and-bank-balance/
Edited by bigjohn
It does struggle to go into reverse now and again, but to be honest I thought that was just a trait of the 'box??
May be just slave cylinder, still gearbox off job though
Go to your motor factor for a parts quote
That wasn't an option for me yesterday, hence the question.
By the fact you have tightness in the low gears and possibly reverse then it's almost certainly a clutch issue. Probably best to ensure an independent orders in all the parts (DMF, Clutch kit & slave cylinder) before car comes in to ensure it is returned quickly
It's confusing me slightly now. Did a S Wales to bristol then up to Birmingham and back run today and it felt ok. It's going into Skoda tomorrow for them to have a quick look, so I will report back.
Any update Jaytip?
