Dash Lights Flickering ( Video Uploaded to YouTube )
Hi.
I have been having this problem with dash lights flickering for a few months now. It wasn't that bad and only used to happen when idle. Now the lights seem to have gone brighter and have been happening even when I drive. Not all the time thou. Only happens now and again.
Cant understand what the problem could be. First assumed it was the alternator but the voltage on the battery when the car is started shows 14v so don't think it is that.
Any one have any idea what it can be?
I tought i would try get some help on the forum before I take it to an auto electrician and see if they can figure out what the problem is.
Any help would be gratefully appreciated.
Thank You
I have uploaded a video to YouTube to show you what the problem is
https://youtu.be/eKfe2paW8BI
Edited by sulayman95
Bit of a disco going on there. Have you checked out the earth's? Also a dying battery is known to do weird things
Sent from my Galaxy S5
Had something slightly similar, but nowhere near as bad and it went after I replaced battery.
How old is your battery and have you ever changed it?
Buy or swop your clocks see if it still happens,i read somewhere its a common issue,normally its just a few symbols like indicators are constantly dimmed.
Nope the battery has not been changed as far as I am aware of. I am not sure it how old it is. A possibility it could be that
Not checked the earth. How would I go about doing that? Is that checking the voltage of the battery using a multimeter?
Ive checked the voltages on the battery. While the engine is off it shows 12.7v and when on it shows 14.0
The battery and alternator seem to be fine...
Battery is showing 12.0 Volts when engine is off. I got it wrong before 12.0 when off and 14.7 when on. Does that mean the battery is on its way out?
One thing I will say about the Octavia is that it is very fickle when it comes to the battery.
There have been so many weird and wonderful threads on here with strange symptoms that have almost always been resolved by replacing what (on the surface) appears to be a working battery.
Bizarrely quite a few of the issues have been completely unrelated to anything electrical.
If the battery is old then for the sake of £70 it won't be a case of wasted money if it doesn't solve the issue.
Yes I'm going to change it after Christmas. Hopefully get a good deal on boxing day  :D
A normal battery should 12.6 and its only showing 12.0 so I think its probably the reason.
Will report back once changed and tested
Lots of batteries to choose from but the Varta E44 gets very good reviews on here and elsewhere. It is a Bosch S5 but without the Bosch sticker!
It is rated well too in terms of Ah and CCA (Cold Cranking Amps).
Some good deals to be had online a lot of battery for £67 delivered...
http://www.ebay.co.uk/itm/Varta-Silver-E44-Heavy-Duty-Car-Battery-77AH-SIZE-096-with-5-year-warranty-/272027548885?hash=item3f561afcd5:g:~yQAAOxygPtS38Ow
Either way you need an '096' sized battery.
Thank You will consider it.
Also I wanted to ask, if you watch the video you see that when I turn the ignition on 6 beeps happen. Is this normal?? The service light isn't on either. Its happened since I purchased it and was curious to know if it was normal or if it was alerting me to something.
Low battery warning!
Did you get anything appear on the radio display?
There have been threads where people have left their doors open with the radio on etc. whilst hoovering the car and they have had the 'bongs' accompanied by the low battery warning on the radio display.
Nope nothing on the radio. But yeah I believe its definitely the battery. Thanks for all your help. Really appreciate it.
Got a great deal for a battery. Got the Bosch S5 for £74 as my local garage whos a good friend has a account with Eurocarparts. £103 on there site !
Now time to keep an eye on it and see if it happens again.
Ive replaced the battery but those beeps keep coming every time I turn the ignition?
Really!?
That beep is only used to warn for the following:
Low temperatures (ice on the road)
Low fuel
Not wearing your seatbelt
Service required
Lights left on
I think it will be a good idea to have the car scanned for fault codes, is there anyone near you with VCDS?
http://www.briskoda.net/forums/topic/224376-vcds-owners-map/
IIRC if you get the six beeps it's a fault notification. On my dad's mkI octavia it happened because of a fault with the rear nearside door.
Sent from my D5803 using Tapatalk
Really!?
Low fuel
Service required
Lights left on
Ahh thats why, I put my seatbelt on then twisted the ignition and no noise lol. I normally start the car then put my seatbelt on lol
Forgot about that. If it bongs when you're wearing your sentient then there's a problem.
Sentient? You mean seatbelt? lol. Yeah no bongs while seatbelt is on so all good  :D
Now I just gotta hope no more dash light flickering.
Stupid autocorrect.
  • 4 weeks later...
Just a quick update, May help anyone in the future with the same problem.
Since battery has been changed the problem has not occurred again.
So all good  :D
Thanks guys
