Brake Rumbling and grating - ABS sensor/Actuator ring fault
Actuator ring slightly damaged in the process of replacement of front near side hub bearing which resulted in the ABS operating incorrectly. Straightened ring with the gentle use of a hammer and problem now only appears when the car is nearly stopped. Need to more carefully adjust the ring but :-
What is the correct gap supposed to be between the ring and sensor?
Hope somebody is able to help!
Many thanks.
