Pads
What pad would you guys recommend for applying a glaze with via a rotary?
Sent from my Galaxy S5 using Tapatalk
Evening buddy,
Personally I apply glaze (if I do apply it) by dual action polisher with a black pad. :)
Sent from my SM-G925F using Tapatalk
Hi James
A Glaze can be applied by hand very successfully BUT
...it can also be applied via a DA with a soft pad
It will depend on the make of pad as to what colour that is
A finishing pad of any make will be fine
Any details on the glaze you might use Buddy?
It could sway what pad I would start with and also depending on paint hardness etc. ie. Is it a full fat filler glaze or with a light cut as well?
Cheers,
Ste.
Any finishing pad would do the trick, but I favour the CG Hexlogic pads.
I tried applying Prima Anigo(Edit: Amigo) via rotary once and it went horribly wrong. The build up of heat made it go all sticky on the paint. You don't get that build up of heat with a DA, hence why the boys are saying to use a DA rather than rotary or indeed by hand.
Hth and enjoy, buddy.
Edited by Hunty278
Cheers,
Ste.
It's KKD Regloss. Picked up just under 1L for a bargain.
Unfortunately I only have a rotary no DA
Ah ok. I think regloss is non abrasive;
Been looking to try this myself actually.
So most likely the softest pad you have...black?
Interested in your thoughts on it James... Keep us uptodate :)
I have a black 3M one. Was looking at the hex logic ones too try.
Yer got this to try and a Fireball drying towel
Also interested in this one, James.
Unsure if it can be used via rotary, but ping Marc a message on Facebook and I'm sure he will let you know whether it can or not.
