Fault code 00153
Hi,
Can anyone help me with this. Code keeps coming back but see no issues with my wipers.
00153 - Windshield Wiper Motor;  Driver Side (V216)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 62
                    Mileage: 63174 km
                    Time Indication: 0
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.15 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
Gary
Here you go, you don't have an aftermarket HID / xenon headlight kit fitted do you?
00153 - Windshield Wiper Motor; Driver Side (V216) 00153 - Windshield Wiper Motor; Driver Side (V216): No Signal/Communication
Possible Symptoms
  • Front Wiper not functioning
Possible Causes
  • Fuse(s) faulty
  • Engine Hood Contact Switch faulty
  • Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216) faulty
  • Windshield Wiper Motor Driver Side (V216) faulty
Possible Solutions
  • Check/Replace fuse(s)
  • Check/Replace Engine Hood Contact Switch
    • See Measuring Value Blocks (MVB)
  • Check/Repair Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216)
  • Check/Replace Windshield Wiper Motor Driver Side (V216)
Special Notes
  • When found in VW Golf (1K): Central Electronics (in Combination with 02071), check for Aftermarket Xenon installation.
http://wiki.ross-tech.com/wiki/index.php/00153
Edited by silver1011
Possible Symptoms
Possible Causes
  • Fuse(s) faulty
Possible Solutions
Special Notes
Thanks, No I don't have any aftermarket kits fitted, just the standard bending xenon's.
