What I need to fit Columbus ?
I have pre fl '09 Vrs with maxidot, and I want to fit a Columbus as Im getting fed up of using my phone for maps as I do a lot of driving.
1) Will all Columbus units work in my car? (I know about the power drain on older mk2's)
2) Is it simply a plug and play ?
3) I know I need a new facia plate, is there anything else I need?
Much apreciated
Not really will need to code it in if u want the navigation to work thru the maxi dot display, other than that maybe a Bluetooth module if u want use ur phone and maybe a mic aswell, if u get a unit already unlocked u can't watch dvds, also if u get a dab unit u will need new aerial and some wire to run to it everything else straight fit
Sent from my SM-G920F using Tapatalk
You will need a GPS receiver (Around £10 from fleabay). When I fitted mine it didn't need coding for the maxi-dot but I was lucky, most will need coding with VCDS.
Great stuff lads, thanks for the quick response
I've just brought a Columbus unit from Rustynuts on here - very helpful guy.
I've brought the following fascia as my car currently has the original unit fitted.
http://www.cars-equipment.com/www/en/shop/navigations/oem-1z0858069dkdf1-navigation-aluminium-trim-for/
So once the parts arrive hopefully I can pop it in easy enough and then have it coded.
The best information I've found on here so far is contained in this link
http://www.briskoda.net/forums/topic/240409-columbus-vcds-procedure/
