Octavia VRS extreme black Alloys and fitting on a MK1
Hi forum,
sorry to jump straight in with a question on my second post
will the extreme black alloys from the currently selling VRS fit my mk1 VRS without any additional work needing to be done
cheers for any help you can provide
deloctaviavrsmk1
Will need an adapted as mk3 is 5x112 PCD fitting whereas mk1 is 5x100
..and the thickness of the adapters (usually around 20mm+) will need to be deducted from the offset - making the wheels stick out more, and possibly catch the arches.
Should be ok with hub adapters, think the MK2&3 offsets are higher then the MK1, IIRC around high 40's/low 50's compared to the 38 on the MK1.
thank you for the guidance i will take a look into this
kind regards
Edited by deloctaviavrsmk1
