anti roll bar bush what size hole to bar diam
as above really,    and  is the answer different depending on fitting plain or poly?   all thoughts  opinions, and theory gratefully received   :nerd:
Depends on what car it is and front or back? Sorry, telepathic powers are lagging a bit tonight.
no you miss the point :sun:     any car any bar----------should they be an exact fit as seems to be the case with poly' or undersize for the bar---be it solid or hollow  as per many factory fit    --  but as yet no one knows /cares   it's a technical//hypothetical question      I'm not expecting a rush :yawn:
Errr, the same then. For example, 16mm bar has a 16mm bush.
