Supercharger pully
Has anyone changed the supercharger pully to a smaller one and if so what sort of change did you get from it
Cheers in advance
That should give you higher low rpm boost, but the supercharger is already geared for fast spining (17,5krpm at 3,5krpm on engine). I would not try on my car.
Ok thanks for the information
Ok cool will look at maybe getting it done not a deffo but just gathering some info on it first
Have you removed the insulation from the Supercharger to get to hear it better.?
There are threads on it if you do a search.  No more power, just more Supercharger noise.
http://briskoda.net/forums/topic/216262-vrs-supercharger-noise
Edited by GoneOffskiroottoot
I believe the supercharger is gear driven too is it not? all sealed up. its boost is turned off as soon as the turbo boosts, so yeah, go for a bigger turbo instead ;)
^^ I stand corrected :)
you cant change the pully since it is a 2 steped design,
