SDI timing belt - changing/cost
As title says really. What kind of mileage should the belt be changed at, and how much would I be looking at dishing out
cheers guys
I had mine changed at just under 60k and paid £325 just for the belt plus tensioners at my usual (non franchise) garage so saved £75 compared to the £400 main dealer quote but still not cheap.
Not an SDI, but my TDI cost me about
is it something I could do myself? I am competent with a socket set
Uhhh, no, not really! The timing belt is the last thing you want to DIY unless you REALLY know what you're doing. If it snaps because of incorrect fitting then your engine is as good as wrecked.
ok. Ive been asked by my local indie garage to source the parts myself.
Should I buy genuine parts? If so where from?
If not, where from?
What parts do I need to give the garage?
i would buy genuine parts from dealer just ask for cambelt kit should inc rollers and tensioner rough price about 120inc :thumbup:
Cheers Drewy, thats great help
www.eurocarparts.co.uk does a bosch timing belt for under 20 quid also rollers are cheap these prices quotedin here are ridiculus you would be stupid to pay 400 quid
It is arguably worth changing the water pump at the same time since if it fails you stand the chance of blowing the head gasket. My neighbour - who is a dab hand at car DIY - changed the cambelt on his Audi A4 1.8T. Unfortunately he fitted the wrong belt which then failed and resulted in major damage to the top end of the engine. He thought he had managed to fix that by replacing all the broken/damaged parts only to have the engine fail on him in a big way when he next went on a long journey. He now needs to buy a new engine for it. :(
