traction control
hi guys need some help traction control light appeared when im not moving or driving slowly so plugged it in to get error intermitant to ecu so erased error for it to come back on im guessing sensor?
Going to need a little more to go on. Do you have a code number?
What system did the code appear in?
sorry cant give anymore info as garage did the code will check on monday
Traction control light (ASR) can normally come on for a few reasons (other than when the system is active). Most common is a broken DFM wire (do you have a battery light with ignition?) and the other is an issue with the Mass Air Flow (MAF) sensor.
hi battery light comes on as normal when starting the light comes on mainly when im parked up or when i slow down for traffic
