£177 inc vat service, they do dozens of Skodas too
The BookMyGarage Full Service includes the following checks:
General Checks
Check operation of external lights
Check headlamp alignment
Check rear reflectors
Check operation of instrument warning lamps
Check Glow plug warning light (if applicable)
Check battery condition and connections
Top up battery (non sealed unit only)
Check horn
Check alternator output
Internal / Vision
Check door/bonnet/lock operation and lubricate locks hinges and catches
Check windscreen wipers and washers operation and condition
Top up windscreen washer reservoir with additive if required
Check & advise on pollen filter condition
Check air conditioning system operation
Check windscreen for cracks and chips
Check mirror condition internal and external
Check number plate condition
Check seat belts
Engine
Drain engine oil
Replace oil filter
Refill with fresh oil
Replace air filter
Replace fuel filter if fitted externally from tank
Check and advise on general oil leaks
Check coolant level and top up
Advise on antifreeze strength
Check radiator, coolant hoses for condition and leaks including header tank
Check radiator cap
Check electrical coolant fan (if applicable)
Check condition and tension of auxiliary drive belts (NOT timing belt)
Spark plugs changes on petrol engines dependent upon mileage - Extra Cost
Check/clean HT leads and components (if fitted)
Test effctiveness of starter motor
Visual check fuel system and tank if visible
Check fuel cap
Check timing belt replacement intervals and advise
Brakes
Check brake servo operation
Check/advise brake fluid boiling point. If boiling point low change brake fluid - extra cost
Top up brake fluid if required
Visual check of brake pads/discs for wear
Visual check all visible brake pipes and hoses
Check operation of handbrake
Visual check brake callipers for leaks and security
Visual check brake discs, brake shoes and cylinders for wear, leakage and damage
Check security of handbrake linkages and travel, and adjust if required
Steering and Suspension
Check condition of road springs
Check power steering fluid reservoir for leaks and top up
Check steering/suspension components for wear and excessive corrosion
Check steering rack gaiters condition
Check shock absorber condition and mounting
Grease steering prop shaft and suspension (if applicable)
Check wheel bearings for noise and play
Drive System
Check drive shaft gaiters for security and report leaks
Check gearbox fluid level
Check clutch operation and adjust (if applicable)
Check clutch fluid level (if applicable)
Check transmission oil leaks
Check condition of clutch cable where fitted and viable
Exhaust
Visually check exhaust smoke (diesel engine only)
Visually check and advise on condition of exhaust
Wheels and Tyres
Check tyre condition and tyre depths
Check and adjust tyre pressures
Remove road wheels and check flanges and mountings for damage
Re-fit road wheels to manufacturers torque specification
Final Checks
Carry out engine management system scan
Reset vehicle service light where applicable
Stamp service book
Stamp printout of BookMyGarage service schedule
Road test
Edited by lichfielddriver
done with VAG parts/castrol oil....£169
all filters oil/air/fuel/pollen
Skoda dealers in Ireland are offering a basic service for €149...
Lol.
How I do it:
*All filters: mann from eurocarparts online with click+collect (last time all were £42)
*Oil: Mobil1 esp formula 5w30 (5L) from ebay (user: opieoils - used them for over 1year now) costs £34-38.
I either do it myself or pay a mechanic friend £20 or a local garage £40 if the friend is not available. And they also check everything above.
Sent from my STV100-4 using Tapatalk
Mine was also £169 which included mot and brake fluid, though I did supply the oil. How? Simply negotiated with the service department and I get a print out similar to the top post.
Edited by Danny 57
I think we are finding main dealers dont realise WE are the customers...
I was a HGV parts/storeman (truck and trailers), if a customer asked for oil+filter change thats what he got, you dont argue with some guy who owns 100 trucks or vans, i once saw a supplier forced to dance on an office table after screwing up an order to keep the customers business, a £50K tractor unit, a £50K fridge trailer, £200K load of yoghurts held up by the wrong £10 valve.....
Mine was the main dealer price.
Im happier dealing with the black-hand gang who call a spade a spade and look after my vehicles instead of supplying a nice showroom to wait in with TV and coffee machine and twee little cups, give me a cracked mug and teabags and im happy, 55 years ago dad used to take me to his firms haulage yard/workshop to play in, maybe thats why im the way i am
