Picked this up...
Need some help on this,picked up tonight.with possible seal damage,for £30 i couldn't moan
Its a Kranzle but not sure on model no numbers on it either.
Haven't connected to water yet,but it runs. ive checked valves they all hold water.
Might just strip clean put in some oil and get it clean and see what happens,seal wise...i know the old units got condensation causing milky oil,
hope its just that.
What oil do people use?
Will any 15w40 mineral do?
6A6F5D12-AAE6-4E7F-8867-0DC8F9DB83A6_zps
Nice one - if you can get it sorted OK..... i have looked at these in the past but just too pricey.
Ideally you do need to try and ascertain the model number.... link below can then help:-
http://www.kranzle.co.uk/files/oil.pdf
Let us know how you get on  :thumbup:
Ive plumbed it in and all is good.just need a service kit...its that powerful it keeps blowing fuse,so i need to run it via house,no biggy ill lengthen the lead with proper cable.
Its the daddy hd10/120 older version.
1 oil seal is leaking and badly corroded.hopefully will clean up.if not a new faceplate.
What a good find plenty of service bits available on bay.
Same model (ish) as mine.
Really solid PW, I will say look for a decent longer hose, the underbody lance (curved) and the vario lance (I have four different lances for various work).
They really are worth spending the extra for.
And yes, they will eat fuses as the start up draw is alot.
I have ordered a new face for it as the seal's come fitted for an extra £20.oil seals are £30.
