XXR 527 + Brembos
Hi, Does anyone know of anyone who has got 527 over a big brake setup,
I'm looking to get the brembo 323 from the Cupra R on the fabia, Does anyone know if my wheel will clear them or do i need to change?
XXR 527 17" 8.25J ET25. Can get pics if needed.
Thanks.
The width of the wheel and the offset look promising,I would say they will clear,but it all depends on the spoke design of the wheel.
Take a pic of the clearance now to your standard calipers, on a angle showing the spoke to caliper clearance.
Hi, these are the pictures i have at the moment, ill go get some pictures with tape measure for distance on my break at work in a bit, these are only ones i had on my phone, i know ride height is off i've got coilovers in garage just not got round to them yetr69YeJ.jpgASTWjk.jpgRNdZA3.jpg
I'm pretty sure they will clear ok,as the spoke to caliper clearance is getting much better as the spoke goes further out,as the Brembos will be further out from the hub due to the bigger disc size.
Good point. :thumbup:
thanks, going to be trying the brakes and coilover fitting this weekend coming up.
where did you get your xxr 527 wheels from.Cant wait to see this once the coilovers are on
