Deep rumbling pinking noise
I have a deep rumling/pinking noise when i accelerate in 2nd gear sometimes 3rd on the drivers side more so when cold  above 2000rpm 2l diesel any ideas what it could be
Edited by skoda1982
If you cude rite corextly perjaps you cud expect an ansa?
I have made a similar posting on this matter. On a cold engine, under load in 2nd or 3rd at about or just below 2,000rpm I suffer a bottom end knocking noise. The car has been back in over the two winters I have owned it regarding this. The first time they managed to replicate the issue, but no faults codes were logged. Out of interest the mechanic took out a stock vehicle owned by the garage and got the same result. His opinion and that of others and internet search results seem to confirm "diesel knock". I believe this is a pre-ignition similar to pinking on a petrol vehicle and a [annoying] characteristic of diesel engines and not a fault. When engine is warm, which can take 15 minutes and oil is up too temperature [90 degrees] I have not had this problem.
Colin
Either way I wouldn't be happy with any sort of 'knock' even if it does go away when hot.
Colin
sounds like the same problem. Does it not have a sensor to stop this like on the petrol engines advance and retard
Are you dyslexic like me
Not that I am aware of. If you apply the power more slowly it does not happen. Likewise when warm.
I would take it into the dealer and let them have a look at it for your own peace of mind.
Colin
Colin
its ok when I apply power slowly. Just when overtaking and the like
Try changing down a gear.
Drive it like a petrol.
