Engine fan keep spinng when i lock the car.
My battery drain problems are almost fix now.
Its the engine bay fans that keep going for 5 seconds then are off for 5 seconds and then starts again.....
what is it that is controlling the fan? The coolant tempeture guage in the car is working fine.
does anyone have a wiring diagram for octavia mk2 vrs pre fl?
I had same problem recently so I Googled. "skoda octavia fan stays on"
There was a few items that popped back but the one that worked for me was that some water had got into the external fuse box after I had rinsed the engine bay.... I tried the hair dryer on it which I didn't think worked that well. It might have displaced some water but not all off it, so I sprayed it with electrical cleaner and that solved it... Hope it's as easy as that for you.
Sent from my Nexus 5 using Tapatalk
Is the AC switched on?
does your cluster display the correct outside temperature?
  • 3 months later...
Did you find a fix to this? I have same fault but also have EML light on showing fan1 control circuit low?
