Exhaust Gas Temp Sender Problem P242a
Hi All,
Using my new MaxiScan MS609 OBD11 after getting the following problem,
( I've had a series of Glow plug light flashing problems )
( Turn off the Ignition and back on Glow plug light goes out for some time )
I have found that I have a malfunction on my exhaust gas temp.
Sensor. Fault code is P242a. Bank 1 Sensor 3.
Sensor. Fault code is P242b. Bank 1 Sensor 3.
All internet discussion point's to the old 03L906088DE
( Before Diesel Particulate Filter )
Two updates for this part New 03L906088GR and 03L906088FG latest model
I am looking to update but have now seen more wiring problems in the same area
I will try and attach pics for viewing Problem Area.
Will keep you updated on how I get on after parts arrive and hopefully I solve the Problem's
Newbie
:D
I forgot to say that my car is :-
Skoda Fabia 1.6 TDI Elegance 2010 ( 26,000 miles )
I hope the Pictures work :-) ?
059 906 051C Diesel Particulate filter Pressure Difference Sensor.
Skoda Fabia 2010 Fault Code P242b
Skoda Fabia 2010 Fault Code P242a
Newbie :-)
Ordered a workshop DVD disk to find what I need to remove to get at the part in question.
Not sure if I can reach from the top ( engine department )
or I need to attack the Sensor from under the car lol.
Will put pics when I start the job.
Regards
Newbie :-)
I have now changed the Exhaust gas temp Sender.
Part Number 03L906088DE Old Part Number with the new Part
03L906088GR.
Coil Light and Engine Light now OFF
Great News :-)
( Not to hard a job to do )
Newbie
Picture's of New & Old Part Number
( 03L906088FG does not fit this model my mistake )
The correct Part Number to fit is 03L906088GR as you can see it is longer at both ends giving a better fit :clap:
Exhaust Gas Temp Sender 03L906088DE Old Part Number - 03L906088GR New Part Number
15.   03L906088DE Removal
I have taken the car for many trips now and every time no longer have the coil light flashing and engine light on :sun:
Will now mark as solved.
Result Newbie.
:dance:
  • 4 years later...
So where is sensor 3 as its clearly only has 2 exhaust temperature sensors on the car. i can see the one near the turbo from the top.
