Stage 1 Re-Map Pre-Requesites
Are there any pre-requisites to having a Stage 1 re-map on a 2007 pre-fl Octavia vRS ?
Tfsi ? Fuel pump cam follower might be a wise move as they are known to fail, decent panel filter if you wanted but not essential just a well maintained car and decent clutch, u won't regret it the difference is night and day.
Dv needs to be healthy. If it's still the standard one it may need changing
Edited by tequilan
It's a TDi
depends in the mileage really, for a stage 1 you don't really need anything to get the benefits to get the max bang for buck, like the post above, a decent after market panel filter like pipercross or K&N. and well maintained car thats all thats needed. the best thing i ever did to mine! effortless to drive than standard
As above
However there is a few cheap things you could do as above panel filter, I went for red coils the R8 ones, k and n panel filter, forge blow off vavle with new type dumper lol, then I have cat back miltec and I think the map has made the most of what I had already done :)
It's a TDi
I could mines done close to 100,000 now on 114+  I have had for over a year now and its running like magic,
I got the Stage 1 with DPF removed and deleted which will cost extra.
I have no other mods at the moment, may get a panel filter however I'm going to concentrate on the suspension next.
1. driver
2. driver
3. driver
4. driver
5. driver
6. once you improve most limiting factor; then suspension
7. driver
8. driver
9. driver
10. driver
11. then you are ready for remap ;-)
Edited by sniper29a
