The difference between pre FL & FL cars
Hi,
In India, the Octavia 2 (called the Laura here) came with a 1.9 PD tdi (105 hp) till 2009 and then the facelifted version came out with the 2.0 commonrail diesel @ 140 hp. Only talking Diesels here.
What is the difference between nonface lift and facelift apart from engines and headlamps ? Any changes to brakes, suspensions, bearings etc?
I am trying to source spare parts online...so every bit of info will help.
quite a few changes:-
- interior changes (seats, centre dash controls, dashboard)
- exterior changes (wing mirrors, rear lights cluster, brake sizes)
- electrical changes (control modules, sensors, wiring looms)
there's more, but that's just a few.
Check out partsbase.org as that will give you part numbers for your vehicle and will also let you search by part number to see what other vehicles used the same.
If you have a full list of PR codes for your car that'll make things easier too! You can get them from a dealer or Erwin online quite cheaply.
